Results 1 to 10 of 16
Thread: Spray in Bedliner
    Mar 2006
    I just got a black 2006 Extended Cab Silverado. Now I want a spray in bed liner. I am trying to decide if it should go over the bed rails or keep the bedliner under the rails and buy some bed rail protectors.
    Any opinions? Any reason to go one way over the other?
    sprayed99 Guest
    <div class='quotetop'>QUOTE(malibujeff &#064; Mar 6 2007, 09&#58;59 PM) [snapback]85519[/snapback]</div>
    Under the rail looks alot better
    <div class='quotetop'>QUOTE(sprayed99 &#064; Mar 6 2007, 10&#58;24 PM) [snapback]85522[/snapback]</div>
    Ive seen it once on a reg cab pewter truck with it coming over the bed rails and I didn&#39;t like it too much. You could do black diamond plate for the bed rails. Just to match the black truck already.
    Over the rails looks like crap when it starts to fade.
    Aug 2005
    St. Anthony, Indiana
    DBYRD Guest
    agreed, contact Red03SilSS he&#39;s does bedliners and can get u a good price prob.
    May 2006
    Waco TX
    Definitely go under. Over is more of a work truck look. Where are you located? We could get you done in about 4 hours and you will Love it. I promise.
    Mar 2006
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Mar 7 2007, 08&#58;00 AM) [snapback]85556[/snapback]</div>
    Thanks for all the feeback. I am in Georgia, so I don&#39;t think I can get out to TX anytime soon.
    Jeff
    What do you charge?
    Jul 2006
    College Station, TX
    go under and over then do diamond plate covers. i have the plastic caps and i wish i had over the rail. I have the good caps and mine are starting to pull up at the corners only after a year and a half.
    2004 EXC Silverado 6.2L
    Mods:
