Results 1 to 8 of 8
Thread: gauge lights
    Mar 2006
    Houston
    anyone know what bulbs are in the gauge cluster and ac control.....i want to change them to blue....got any places to buy them and how many i need....any suggestions....thanks
    2001 seirra 5.3L ex cab.-- 93 performance Nelson Tune,longtube pacesetter headers, ory, magnaflow with electric cut out, airaid cai, throttle body spacer, clear corners, 1400 watt system, 2 ifinity tens custom boxes, panasonic head unit, punch grill....sold :-(
    09 camry se v6....gotta have a gas saver while in college...still gets up and goes tho
    http://www.gmfullsize.com/forum/showthread.php?t=24726
    Thats everything you need to know right there. The bulb ordering link is on there along with the connectors. Make sure you read it to see which bulb you need. Im pretty sure its the 4 bulb 194. Hope that helped.
    Mar 2006
    Houston
    <div class='quotetop'>QUOTE(duckysbht &#064; Jan 24 2007, 06&#58;09 PM) [snapback]81078[/snapback]</div>
    thanks....but i need to know how many i need maybe i missed it...y are they so expensive 7 bucks a pop....
    Your going to need six im pretty sure. but they arent 7 bucks a pop.. I dont know which ones your looking at.
    Mar 2006
    Houston
    <div class='quotetop'>QUOTE(duckysbht &#064; Jan 24 2007, 06&#58;45 PM) [snapback]81085[/snapback]</div>
    im confused on which ones to get....on this site http://www.superbrightleds.com/cgi-b...e/commerce.cgi ...WLED 4-LED bulb , T13 Wedge Base , 921-x9 Wedge Base, 921-x12 Wedge which ones lol....there so cheap but so much trouble to find which one
    Jan 2007
    will this also work for a 2004 cluster??
    <div class='quotetop'>QUOTE(04silveradoclone07ss &#064; Jan 24 2007, 07&#58;05 PM) [snapback]81090[/snapback]</div>
    I think they will work on the 03+ clusters but you have to do alot of saudering. For some reason they are different clusters than the 99-02 and its harder..
    <div class='quotetop'>QUOTE(blackout00 &#064; Jan 24 2007, 10&#58;26 PM) [snapback]81123[/snapback]</div>
    YOUR KILLING ME SMALLS led ordering page <--- Go there. When you get there start at the top and count down 12 Lights. When you get to the 12th set of lights, go to the left and click on the drop down that says, "select LED color" Click "blue". After you do that go right underneath it and type in "6". Once you do that go to the far right and click "check out".
    Now your going to need new Twist locks because your stock ones are sauldered in. Go here Twist Locks. Order 6 of those.
    Once you order them, it usually takes about 10 mintues to take your dash off, unscrew the four bolts holding the cluster in, pull it out, unplug it, take the back off of the cluster, remove the old bulbs and twist locks, and then put the new ones in. BE CAREFUL btw.
    Oct 2006
    as ducky said, the 03+ clusters have to have the lights soldered into them. you&#39;ll need 6 4LED 194&#39;s to do the 99-02 cluster.
    13.4 @ 98mph. Cammed/Stalled/LTs/Tune and those lame 3.42s!
