Results 1 to 10 of 25
Thread: 2" valves in 862s
    2" valves in 862s
    I'm wanting to do valve upgrade on my 862 heads, 2" valves intake and have them milled n hand ported an polished. Can I just throw the valves in and go what needs to be done to accomplish this.
    Pittsburgh, PA
    about 4 yrs ago Texas speed did a test with installing 2" valves in these heads. the results showed the stock size valve netted better performance then the 2" valve. had to do with the larger valve hurt flow of the head. look on ls1tech in the gen3 section and go back 4 yrs if possible.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    So it be best just hand p&p and get them milled?instand of the 2" valve upgrade
    Quote Originally Posted by fordkiller91 View Post
    thats what i would do but then again id just get some 2.5 heads from TSP
    Simple: 408 on steroids!
    single digits coming soon!
    don't the prc 2.5 5.3 heads come with 2.02' valves?
    Quote Originally Posted by o2camaross View Post
    yes they do, but the way they are cnced makes it all that much better, i used to run them on my lq9! theyre great heads!
    Good to know, thanks skeet. You notice a decent gain?
    Can't afford prc heads right now.. just want little more low end torque and more commpression
    Which do y'all think be. Better milled p&p 2" valve upgrade or just 243/799 heads and milled them .030-.045
    Arizona/Utah
    243 with a proper P&P+milled .030 is a bad ass head for the money. JMO.
