Results 1 to 10 of 20
Thread: PCM pinout diagrams
    PCM pinout diagrams
    2001 silverado (Thanks Banker099)
    This image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.
    Powertrain Control Module (PCM) C1 (BLU)
    Connector Part Information
    • PCM Connector C1 Assembly 12191489
    • TPA (BLU) 12176408
    • Connector Cover 12191108
    Pin
    Wire Color
    Circuit No.
    Function
    1
    BLK/WHT
    451
    Ground
    2
    LT GRN
    1867
    12 Volt Reference
    3
    PNK/BLK
    1746
    Fuel Injector 3 Control
    4
    LT GRN/BLK
    1745
    Fuel Injector 2 Control
    5-10
    Not Used
    11
    LT BLU
    1876
    Knock Sensor 2 Signal
    12
    DK BLU/WHT
    1869
    CKP Sensor Signal
    13
    ORN/BLK
    463
    Requested Torque Signal
    14
    ORN/BLK
    1061
    UART Serial Data [Secondary]
    15
    DRK BLU/WHT
    774
    UART Serial Data [Tertiary]
    16
    Not Used
    17
    DK BLU
    1225
    Transmission Fluid Pressure Switch Signal B
    18
    RED
    1226
    Transmission Fluid Pressure Switch Signal C
    19
    PNK
    439
    Ignition 1 Voltage
    20
    ORN
    440
    Battery Positive Voltage
    21
    YEL
    1868
    Low Reference
    22
    Not Used
    23
    PPL
    719
    Low Reference
    24
    Not Used
    25
    TAN
    1671
    HO2S Low Signal [- Bank 2 Sensor 1]
    25
    TAN
    413
    HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
    26
    TAN
    1667
    HO2S Low Signal [- Bank 2 Sensor 2]
    26
    TAN
    413
    27
    Not Used
    28
    TAN/WHT
    1669
    HO2S Low Signal [- Bank 1 Sensor 2]
    28
    TAN
    413
    29
    TAN/WHT
    1653
    HO2S Low Signal [- Bank 1 Sensor 1]
    29
    TAN
    413
    30
    LT GRN
    1478
    Coolant Level Switch Signal
    31
    Not Used
    32
    BLK/WHT
    771
    Transmission Range Switch Signal A
    33
    PPL
    420
    TCC Brake Switch Signal
    34
    WHT
    776
    Transmission Range Switch Signal P
    35
    GRA
    48
    CPP Switch Signal
    36
    BLK
    1744
    Injector 1 Control
    37
    YEL/BLK
    846
    Injector 6 Control
    38
    PNK/WHT
    1101
    Damping Lift/Dive Signal
    39
    Not Used
    40
    BLK/WHT
    451
    Ground
    41
    BLK
    407
    Low Reference
    41
    GRA
    720
    Low Reference (w/o Delphi HO2S)
    42
    Not Used
    43
    RED/BLK
    877
    Fuel Injector 7 Control
    44
    LT BLU/BLK
    844
    Fuel Injector 4 Control
    45
    GRA
    474
    5 Volt Reference (FTP Sensor)
    46
    GRY
    474
    5 Volt Reference (TPS Sensor)
    47
    GRY
    597
    5 Volt Reference (MAP Sensor)
    48
    GRA
    596
    5 Volt Reference (EGR Sensor)
    49 50
    Not Used
    51
    DK BLU
    496
    KS [1] Signal
    52
    Not Used
    53
    BLK
    470
    Low Reference
    54
    BLK
    452
    Low Reference
    55
    BRN
    1456
    EGR Valve Position Signal
    56
    Not Used
    57
    ORN
    440
    58
    DK GRN
    1049
    ECM/PCM/VCM Class 2 Serial Data
    59
    YEL
    710
    Class 2 Serial Data
    60
    ORN/BLK
    469
    Low Reference
    61
    PNK/BLK
    632
    Low Reference
    62
    Not Used
    63
    GRA
    720
    Low Reference
    63
    TAN
    413
    64
    Not Used
    65
    PPL
    1670
    HO2S High Signal [- Bank 2 Sensor 2]
    66
    PPL
    1666
    HO2S High Signal [- Bank 2 Sensor 1]
    67
    Not Used
    68
    PPL/WHT
    1668
    HO2S High Signal [- Bank 1 Sensor 2]
    69
    PPL/WHT
    1665
    HO2S High Signal [- Bank 1 Sensor 1]
    70
    BRN
    1174
    Oil Level Switch Signal
    71
    Not Used
    72
    YEL
    772
    Transmission Range Switch Signal B
    73
    BRN/WHT
    633
    CMP Sensor Signal
    74
    YEL
    410
    ECT Sensor Signal
    75
    PNK
    1020
    Off/Run/Crank Voltage
    76
    BLK/WHT
    845
    Fuel Injector 5 Control
    77
    DK BLU/WHT
    878
    Fuel Injector 8 Control
    78
    Not Used
    79
    WHT
    687
    3-2 Shift Solenoid Valve Control
    80
    ORN/BLK
    510
    Low Reference
    • TPA (RED) 12176410
    Pin
    Wire Color
    Circuit No.
    Function
    1
    BLK/WHT
    451
    Ground
    2
    BRN
    418
    TCC PWM Solenoid Valve Control
    3
    TAN
    1465
    Fuel Pump Relay Control [- Secondary]
    4
    Not Used
    5
    TAN/BLK
    464
    Delivered Torque Signal
    6
    RED/BLK
    1228
    PC Solenoid Valve High Control (Sol. A)
    7
    RED
    1676
    EGR Valve Supply Voltage (5 Volt)
    8
    LT BLU/WHT
    1229
    PC Solenoid Valve Low Control (Sol. A)
    9
    DK GRN/WHT
    465
    Fuel Pump Relay Control [- Primary]
    10
    WHT
    121
    Engine Speed Signal
    11
    DK BLU
    604
    A/C High Pressure Recirculation Switch Signal
    12
    Not Used
    13
    LT BLU/BLK
    396
    Cruise Control Engaged Signal
    14
    Not Used
    15
    BRN
    25
    Charge Indicator Control
    16
    GRY/BLK
    1694
    4WD Low Signal
    17
    DK GRN/WHT
    2523
    A/C Request
    18
    Not Used
    19
    BLK/WHT
    1695
    Axle Switch Signal
    20
    LT GRN/BLK
    822
    VSS Low Signal
    21
    PPL/WHT
    821
    VSS High Signal
    22
    RED/BLK
    1230
    AT ISS High Signal
    23
    DK BLU/WHT
    1231
    AT ISS Low Signal
    24
    Not Used
    25
    TAN
    472
    IAT Sensor Signal
    26
    PPL
    2121
    IC 1 Control
    27
    RED
    2127
    IC 7 Control
    28
    LT BLU/WHT
    2126
    IC 6 Control
    29
    DK GRN/WHT
    2124
    IC 4 Control
    30
    Not Used
    31
    YEL
    492
    MAF Sensor Signal
    32
    LT GRN
    432
    MAP Sensor Signal
    33
    DK GRN
    1614
    Recirculation Actuator Control
    34
    DK GRN/WHT
    428
    EVAP Canister Purge Solenoid Control
    35
    Not Used
    36
    BRN
    436
    AIR Pump Relay Control
    37-38
    Not Used
    39
    RED
    631
    12 Volt Reference
    40
    BLK/WHT
    451
    Ground
    41
    WHT
    257
    EGR Solenoid Control
    42
    TAN/BLK
    422
    TCC Solenoid Valve Control
    43
    DK GRN/WHT
    459
    A/C Compressor Clutch Relay Control
    44
    Not Used
    45
    WHT
    1310
    EVAP Canister Vent Solenoid Control
    46
    BRN/WHT
    419
    MIL Control
    47
    YEL/BLK
    1223
    (2-3 Shift Solenoid or Shift Soleniod B) Valve Control
    48
    LT GRN
    1222
    (1-2 Shift Solenoid or Shift Soleniod A) Valve Control
    49
    YEL/BLK
    1827
    Vehicle Speed Signal
    50
    DK GRN/WHT
    817
    VSS Signal
    51
    YEL/BLK
    1227
    TFT Sensor Signal
    52
    GRA
    23
    Generator Field Duty Cycle Signal
    53
    Not Used
    54
    PPL
    1589
    Fuel Level Sensor Signal [- Primary]
    55
    DK GRN
    603
    A/C Low Pressure Switch Signal
    56
    Not Used
    57
    BLK
    552
    Low Reference
    58-59
    Not Used
    60
    BRN
    2129
    Low Reference
    61
    BRN/WHT
    2130
    Low Reference
    62
    GRA
    773
    Transmission Range Switch Signal C
    63
    PNK
    1224
    Transmission Fluid Pressure Switch Signal A
    64
    DK GRN
    890
    Fuel Tank Pressure Sensor Signal
    65
    Not Used
    66
    PPL/WHT
    2128
    IC 8 Control
    67
    RED/WHT
    2122
    IC 2 Control
    68
    DK GRN
    2125
    IC 5 Control
    69
    LT BLU
    2123
    IC 3 Control
    70-71
    Not Used
    72
    BLK/WHT
    3122
    HO2S Heater Low Control [- Bank 2 Sensor 1]
    73
    DK BLU
    1936
    Fuel Level Sensor Signal [- Secondary]
    74
    LT GRN/WHT
    3213
    HO2S Heater High Control [- Bank 2 Sensor 1]
    75
    Not Used
    76
    LT GRN/WHT
    1749
    IAC Coil B High Control
    77
    LT GRN/BLK
    444
    IAC Coil B Low Control
    78
    LT BLU/BLK
    1748
    IAC Coil A Low Control
    79
    LT BLU/WHT
    1747
    IAC Coil A High Control
    80
    LT GRN
    2002 Fbody
    Spiro, Oklahoma
    Got any for DBW?
    england uk/San Diego
    dbw tb and tac mod
    97/98-04/05 vette/early suv 01 dbw tb
    tp sensor
    new project
    37 m-series 3/4 ton chevy truck,
    plans: 5.3/4l80e, cut down ford 9 inch, 6piston brakes
    newer dbw set up
    newer dbw set up
    new project
    Nice!
    Southwest AZ
    Would you guys happen to have the wiring schematic for the PNP or PRNDL or gear position switch (12pin connector) located on driver side of a 2005 2WD Silverado w/ 4L60E trans? Original harness & connector were damaged beyond repair, bought new harness w/connector but can't figure out where they get connected to or which Pins on PCM they get pinned into...
    Thanks in advance
    2008 2WD Ext Cab 6.0 VMAX--MODS...CL MAF OnlyTUNE w/AFE CAI, Corvette Servo, Flowmaster 50 Series, Innovative LM-2 WBO2
    1998 S-10 4.3 V6-0411 PCM-Crower(Cam, Lifters, Rockers) JE Pistons, T-56 6 Speed, Innovative LM-2 WBO2
    [B]EFI Live FlashScan V2 & AutoCal[B]
    Apr 2004
    Can anyone tell me if the pinout for a 1999 5.3 is the same as the 2001 posted in this thread?
    Gus
    I am using the PCM #12597121 (58x reluctor) from a 2007 NBS ,along with the wiring harness (has no tac module) and pedal setup for my LS2......I want to get started seperating unneeded wires and such....where could I find the pin out chart and other related info for this wiring set up? I understand it is not a huge deal to link the cruise mode from the new setup to the '93 GMT400 harness? Thanks
    '93 Chevy Sport... LS2...T56 Magnum..."Red Rider" under construction.........
    Quote Originally Posted by dustiebutt View Post
    IIRC the LS2 came with both reluctors at different year models. Does it have the original crank sensor and if yes, what color is it? If no then look in the hole where the sensor goes, is there one plate in there or two stacked together? 58 will have one and 24 will have two.
