Results 1 to 7 of 7
Thread: alignment issues
    Jun 2012
    alignment issues
    idk if i put it in the right section but, i got drop spindels and springs but my alignment is off cuz its eating my tires from the inside.. what can i do to fix it?
    Quote Originally Posted by jr56 View Post
    Did you get it alligned after you installed the spindles?
    Jun 2012
    yeah i got it aligned but its still eating em, ive hird to put the djm arms but i really dont want too low cuz it already rubs sometimes
    Jan 2012
    DFW, TEXAS
    any pics of the alighment sheet? what brand of spindle and springs? Are the springs cut? Who did the alignment?
    Mar 2011
    San Antonio
    I had the same problem, i have a 2/4 fronts on Djm coils. Turned out it was the alignment. Got new tires and had it cheaked it was still under warranty.
    2000*GMC longtubes nelson tune, built trans,trutrac circle d 278 mm stall 373 posi,100 shot of dope and 228 232 588 595 cam.
    Jun 2012
    let me see if i can find the sheet.. springs are djm and spindles are belltech
    Round Rock, Texas
    That's the nature of the beast with modified suspension. There are aftermarket alignment cams that give more adjustability, which may fix your problem. The other issue I've had is the alignment tech not tightening the alignment cams all the way. Also check the ball joints.
