Results 1 to 10 of 13
Thread: What year trannys work??
    Nov 2011
    NH
    i have a 1999 gmc sierra reg cab short bed 4x4 and i swapped the5.3 for a 6,0 . now i need to get a 4l80e to replace my 4l60e. what year trannys will work with that swap?? also what transfer case do i need??? thanks guys
    Nov 2011
    Arlington, Tx
    Quote Originally Posted by kbomhower View Post
    not sure about the transfer case but as far as i know you can use any year 4l80e for the swap.
    PERFORMANCE-TUNING-FABRICATION
    12617 FM 917
    Alvarado, TX 76009
    Any trans newer than yours will work. Ur tcase will work.
    Just need that input gear for the tcase that accepts the 80e output shaft.
    Nov 2011
    Arlington, Tx
    You can use older 80e's as well, mine Is out of a 93 Rv
    12617 FM 917
    Alvarado, TX 76009
    Feb 2011
    cleveland
    Would it be cheeper to use the transfercase from a 2500 with a 80e? or will it even work?
    Nov 2011
    NH
    ya thats what im wondering. i want to find the best deal on a trans and transfer i can to get my truck on the road.i found some from a 98 but its the older body style so i wanna make sure befor i buy it.
    Nov 2011
    Arlington, Tx
    24x or 58x?
    12617 FM 917
    Alvarado, TX 76009
    Nov 2011
    NH
    whats that mean??
    i think he wants to know if you have a gen3 or gen4 engine. What color is the crank sensor, up next to the starter on the side of the block? Black is gen3 and white or grey is gen4.
    Nov 2011
    Arlington, Tx
    yes thats what i wanted to know
    what year is it?
    12617 FM 917
    Alvarado, TX 76009
