well i posted over on PT about this , still havent found the issue, even bought a ATSG book that came in today which seems to be a waste of money, it has some good info about the parts but i'm needing a book that shows step by step how everything is assembled because i think theres two parts that the snap rings came off because when i took the tranny apart the snap rings were popped off. anyways heres the story of what happened
was driving to waycross to help my buddy with a motor swap. stopped on a side road to take a piss, went to get back onto the highway under about part throttle maybe, got to around 20-25 and it went to shift into 2nd and i heard a loud bang and then the rpms started going up but i wasnt gaining speed at all.eased out and slowly mashed the gas and it started going, let it get to about 55 and was wondering what was going on so floored it, rpms pegged and i was going no where again like it was slipping. pulled over to check, nothing was leaking, fluid was fine. so i went to get back in and put it in drive and it wouldnt go anywhere, rpms would just pegg, pulled it to 3rd, same thing, pulled it to 2nd it slowly started pulling off but still could tell something was wrong, pulled it to 1st and it was fine. had to manually shift it through town because everytime i let it drop below 30ish in drive it would pegg rpms and go no where. well if i start in 1st i can floor it, easy out and shift into 2nd, floor it in 2nd, same with 3rd. i can hold it to the floor in each gear and it not slipp once, just when it goes to change gears it wanted to and when having it in drive. the gear band is fine no wear so i know that wasnt slipping, clutches are fine no wear there either.
i figured something broke in the tranny but i have the tranny apart and cant seem to find anything broken, could it be my converter???
i need to figure out whats going on soon, its been down two months and i dont even know whats wrong with it, like i said i also need a link or some info on what book to actually buy because the one i bought doesnt even have pics of the tranny going together, its the revised edition for 4L60R/4L65E.
my truck is a 2002 gmc sierra 5.3 with 4L65E
any help is greatly greatly appreciated
