Thread: 99 Tahoe 2door LS Swap
    I am looking for information in regards to the wiring / rewiring of the harness to run a 2006 Escalade 6.0 with Auto trans in my 1999 2 door Tahoe with Auto trac. I am sure this has been done before but I have not found if it is best to do the repin to the 0411 computer and add what is needed Any information would be helpful
    Thanks in Advance
    May 2007
    Oak Forest, Illinois
    Quote Originally Posted by J-Rod_Almighty View Post
    Thanks in Advance
    I have received your PMs on two different forums and have sent you the info twice now. Check your spam.
    Jeff
    I never received the info Sorry. It is not in my spam folder either. I do not know what to say. I did just PM you with a different email address. Maybe it will work. If you could resend that would be great
    Thanks again
    Jarrod
    May 2007
    I am answering this thread almost 10 hrs after you posted that you sent me a PM. I have no PM from you as of right now.
    Jeff
