Well the swap has officially started and I figured I'd try to document it best I can. This is a 1993 Chevy Z71 with a 350 TBI and a 4L60E tranny. The donor is an LT1 engine and computer from a 97 T/A.
-Electrical - I've decided to use the factory harness from the LT1 and doing a little splice work. More details on this when I get there.
-Accessories - I debated on using the Vette bracket to relocate the accessories to the driver side but after careful measuring I don't think that will be necessary. I am going to use an A/C delete pulley for now and later on install an A/C relocation kit I found on Bowers Race and Rod Shop to mount the compressor high on the driver side. Will also have to have custom A/C lines made, but that will be later. The 2/80 A/C will have to work for now.
-Power Steering - The power steering lines will fit into my gearbox and the reservoir will be mounted on the passenger side of the engine compartment.
-Radiator - I will be using the T/A radiator for ease of routing the coolant hoses.
-Fuel - I bought and installed an intank fuel pump for a T/A and used the factory sending unit from the truck. I think that I'm going to take the easy way out and use rubber fuel line from the truck lines to the fuel rail.
-Exhaust - I already have Flow Tech shorty headers that I will be using with a high flow cat and Flowmaster 40 series muffler dumped before the axle.
- The old TBI will be out, engine compartment cleaned, and LT1 stabbed tomorrow. Then the real fun begins. I will keep this updated.
Pics Here - Ian Robinson's Photos - LT1 Swap Pics | Facebook
