Results 1 to 10 of 33
Thread: Oil pressure
    Feb 2008
    Shreveport, La
    Exclamation Oil pressure
    Ok so I'm driving home and look down and my oil pressure gauge was maxed out at 80 psi?????? Thought it was a fluke so I shut the truck off let it sit for a few, started it back up and 80 psi right off the bat! I have been just poking around in the truck due to large amounts of water falling lol. I have not sprayed it in 2 months cause I haven't been to the track. So I'm lost at what's wrong??????????? O yeah I have no CES or any other lights on?????
    Last edited by TATERNATOR; 10-12-2009 at 01:00 AM. Reason: Cause I'm baller status
    txstvanwilder: but i got lube so i didnt complain
    mean05: he told me a price and i bent over and lubed up
    truckinL33: 6'' is not enough, and 12'' is too much
    pcmcobra: don't drink and bid on egay...lol
    408.Luke: lol im not blowing im investing
    Cromwell, CT
    with the key on engine off will it go to zero or go to 80?
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Feb 2008
    Shreveport, La
    Quote Originally Posted by straightaxle View Post
    stays at 80
    Oct 2009
    huntington indiana
    sending unit bad?, inexpensive place to start
    Sep 2009
    Charleston, SC
    Both sending units and clusters are problematic in our trucks. Find someone with a Tech2 to do a guage sweep test. If that passes replace the sender. Ive replaced many sending units for this problem.
    03 ecsb LS1Cam (4now), Electric Fans, Exhaust, Ported TB, rebulit 4l60 w/shift improvements&stall 130amp Alt,Magnaflow exhaust
    http://www.cardomain.com/ride/3101653
    Jun 2009
    Dublin, Ga.
    could be the sending unit wire grounding out if it instantly goes to 80psi.
    Feb 2008
    Shreveport, La
    is the truck ok to drive?
    If I were to guess, I would say yes.
    Pull the plug out of the OP sensor and see if there is water in it. If yes, blow it out with something. That canned dust spray for cleaning keyboards should work.
    Jun 2009
    Dublin, Ga.
    if it's got oil pressure then yes, but if the guage/sender is bad and the is no oil pressure then no. but i would go out on a limb and say it would be safe to drive as is since it's saying full pressure.
    Quote Originally Posted by TATERNATOR View Post
    If you lost oil pressure, your lifters would be the first indication. They would sound like a sewing machine on steroids. Then you would then hear the rods a knocking. I agree with the others - it sounds like a sending unit problem. But if you have to drive it in the interim, put an egg between your foot and the gas pedal.
