Results 1 to 10 of 20
Thread: have a couple prob after the ls1 swap into my 89 sw scb
    ok so we have finished up the swap with the 5.3 ls based motor into my 89 gmc single cab short wheel base
    deff was a learning experience lol
    but i still have not figured out how to get my stock spedo, water temp, or gas level gauge has anyone elso had this problem??
    any ifo that can help me out would be greatly appreciated
    as of right now im using the spedo on my radar and have a aftermarket water temp gauge in the truck but i would like for the stock gauges to work as i do like them very much
    thanks
    Cody
    use the stock 89 water temp gage. Speedo, haven't done one in a 89, its a little different that my 93-93s. Have you tried tieing the speedo sensor pickup to the factory truck speedo wiring? If it doesnt work the first time, reverse the wiring.
    Fuel level should not have been affected, its in its on wiring loom coming from by the steering column, going to the fuel tank. You may have damaged it when swapping pumps. Or forgot to ground the fuel tank on the frame.
    have not tried anything on the spedo we will try doing that though
    i checked the wiring for the fuel tank and it is grounded back to the same location where i removed it from il just have to check into in more i guess
    do they make an adapter for the water temp sending unit so it will work correctly?? or will it screw into the 5.3?
    You'll likely need an adapter. You can get them through Welcome to Street & Peformance or Summit Racing – High Performance Car and Truck Parts l 800-230-3030 . I think the water temp adapter is 12mm x 3/8 npt but may be different on your engine. I trust the guys at S&P to get it right. They can get you an oil pressure adapter, too, if you want to do one of them. Many people just tap the oil cooler return block above the oil filter.
    yeah thats what we did was tap oil cooler return and it works great
    il have to check into the water temp adapter
    Monett Mo
    temp gauge
    You could also get a temp switch for the 98 camaro and use the tps sensor wires from the tbi harness and that would allow the ecm to receive its signal and send the signal to your dash.
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
    the temp reading will be way off using the 98 sending unit. Tried and failed.
    Monett Mo
    I do agree with that Ive just learned where it runs at.
    yeah we already tried that pegs out the gauge
    Jul 2009
    do you have any pictures? I am getting started on doing this in my 89 this weekend
