Results 1 to 10 of 11
Thread: Dipstick removal ???
    Oct 2008
    Houston
    Dipstick tube removal ???
    How the hell do you get the dipstick tube out ???
    Dont see any retaining bolt or clip.
    Remove starter ?
    oil dipstick is bolted to the side of the head above the exhaust manifold. Unbolt it and twist, turn and pull.
    Oct 2008
    Houston
    Got it, it was stuck in hole a little.
    Mar 2006
    Mesquite
    Putting it back in is even more enjoyable...
    ff_jeff Guest
    Mine just popped right back in. Kinda like the injectors.
    Oct 2008
    Houston
    Was easy to get back in ....... my ex-wife always said I had good penetration skills
    Jun 2007
    i faught to get mine back in ,with a new o-ring on it.it makes a diff how it goes in if you have headers.diff,angle.
    I'm gonna get a lokar one if i ever have to r and r mine again. Also the tranny dip stick. I hate that thing
    Grease the o-ring and it should go right in.
    HAHA...yeah, make sure to disconnect the battery. TRUST ME.
