2000 5.3l & 4l60e wont start
Got all my wirring and plumbing done tonight so I thought I would see if it would start.
Engine cranks fine and sounds like one cylinder is trying to fire.
Sounds like all eight are hitting when you spray fuel in the throttle body.
I have not had the PCM reprogrammed YET.
I have 12v at the injectors and coils. I did not have my noid lights with me so I will check that and fuel pressure in the morning.
Is it posible that VATS is causing it to not start?
1990 SWB 2000 5.3l 4l60e
It's in just tieing up the loose ends.
