Results 1 to 10 of 11
Thread: Crank Pulley
    Crank Pulley
    Can anyone tell me a pretty good step by step of how to install one. I know to heat it up and slide it on, but I wanna make sure I dont f*ck nothing up in doing that. Any suggestions would help out.
    Thanks,
    david
    Honestly, I haven't found a GM manual yet that says to heat or warm one up. I use a piece of all thread that is cut off longer than a factory bolt and draw it on with a ratchet. That's just me. I run a piece of small chain through the balancer to hold it still since I don't have a fancy tool to do that. Then again, I have found a GM manual yet that says to use a piece of chain or holder to keep the crank from turning.
    Aug 2005
    St. Anthony, Indiana
    Allen taps them on with a hammer far enough to be able to use the old bolt, then use an impact and pull it in.
    Im just worried if i try and tap it on with a hammer I will fracture the edging of it. This last pulley I had on there had a small fracture on the edge thats why im gonna replace it. Should I put a small piece of wood in between and then tap or use a rubber mallet?
    take a socket or pipe and tap on the center, not on the pulley edges. BTW, the pulley has a rubber isolator and hitting on the outside of it could fracture the bond.
    I never thought of hitting the middle of it. I think ill try that. Jeff Smallen was the one that was telling me to heat up the snout of the pulley and he said it just slides right on, after its butted up all the way. Then once it cools its set on their..
    Yeah, warm it up a little but dont cook it. I know it works, I've tried it. It is so easy with heat. I'm just saying that the GM books never suggested the easiest install method. Use propane, not oxy/acetylene.
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    I just lubed my crank snout w/ some 30W, got it on as far as it'd go... then used some threaded rod to get it down.
    37ft-lbs, then 140° CW.
    San Marcos Texas
    I was amazed at how little heat it took to make it fit. Smear a little grease on the hub, when it just starts to melt install it.
    Apr 2005
    I put it in the oven. Not sure that was the best method either, but it worked.
    Gone, but not forgotten!
