Results 1 to 5 of 5
Thread: anybody know why?
    I called the local gm dealer and they told me the 2001 4l80e was a one year only transmission.what makes it different then the rest?I am swapping the 6l and 4l80e from a 2001 gmc 4x4 into an 82 2wd fullsize blazer.so do i have to run the 2001 trans or does that matter with my swap?
    Thanks
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(last2wd &#064; Feb 18 2007, 10&#58;47 AM) [snapback]83697[/snapback]</div>
    Thanks
    I don&#39;t know about the "one-year" transmission, but I question why you&#39;re putting a 4x4 trans (w/ tansfer case) in a 2wd vehicle. Maybe I&#39;m , unless you&#39;re swapping the output shaft to a 2wd shaft.
    <div class='quotetop'>QUOTE(1BADC10 &#064; Feb 19 2007, 06&#58;06 AM) [snapback]83763[/snapback]</div>
    I know need to replace the transmission with the 2wd version or swap output shaft and tail housing.Just wondering if I do swap the 4x4 unit(instead of converting it over to the 2wd output) If the new 2wd replacement would need to be a 2001 cause the gm dealer here says the only trnsmission i can run in it is the 2001 year because they are different from the earlier year ones and the 02-06 ones.Just wondering if that would matter with my swap or not?Or could i use a different year transmission?The 2wd 4l80e&#39;s are very hard to find here even a core seems impossible to get
    It could be only the valving in the transmission. At one point they changed the tranny housing from a one piece unit to one with a removable bell housing, I believe. Much earlier they upgraded the internals.
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Feb 19 2007, 12&#58;16 PM) [snapback]83799[/snapback]</div>
    Thanks Red
