Results 1 to 5 of 5
Thread: 5.3L heads on a 4.8L
    Jan 2007
    Hurst
    It wont show any improvement will it considering there stock right? Will it just drop compression?
    Aug 2006
    Willis, TX
    <div class='quotetop'>QUOTE(Jaw_Dropper &#064; Jan 8 2007, 08&#58;54 PM) [snapback]78780[/snapback]</div>
    I believe the 4.8 and 5.3 use the exact same head
    01-06 casting 862 in/ex Vol(cc) 200/70cc -----ComChmb(cc)61.15
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    yep, same exact heads.
    Jan 2007
    Hurst
    awww that sucks i got a pair just laying around in my storage facilty that we took off a van. I knew there were couple things that can be interchangable between them just didnt know the heads were the same.
    What size valves do you think I can put in them I&#39;m wanting to fully port and polish them? Can i go with a 2.05 intake with the factory heads or is that to big? What size exhaust size should i look into? Any help is appericated. I want the most i can push out of the factory heads.
    Thanks
    May 2006
    Grab the heads get them milled to run 10.5:1 Compression and get a mild port & polish.
    Add a Z06 cam, LS6 intake, 3,000-3,500 stall, 1 5/8" Long tube headders w/full exaust 2.5", pcm tune & 4.11 gears w/ posi.
    You won&#39;t be sorry
    Hey that&#39;s a wicked combo. I&#39;d like that on a 5.3 single cab a a lil larger cam & a 125 wet shot&#33; Woo hoo&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;
    http://www.angelfire.com/alt/americanscrapmetal/4.jpg
    2006 Ext Cab LT 1500 4.8 Auto.
    Mods:
    K & N, MAF descreen, Cold air tube, Ported TB, TB Bypass, Predator tuned, No cats, Dual exaust w/Flowmasters, 4.11 Yukons w/posi, 160 Stat, Tranny cooler
