Thread: 00 5.3 swap into a 93 5.7 auto!!
    Nov 2006
    I have found 00model 5.3 with harenss and ECM for 500 with like 60k. I was just wondering what all its gona take to do it thanks guys.
    Oh yeah Ill try to post some pics of it tommrow.
    Dec 2003
    Newark, Tx.
    I'm doing a 4.3 to '05 5.3 as we speak.
    I'll try and tell you a few things that I can remember.
    You'll need v-8 frame mounts and motor mounts for the 93. You will need a set of adapters. You can get them off of ebay for about $40.00.
    If you know how, you can cut down your harness out of the '00. If not, I would get with Nelson Performance. He has a custom harness for GEN III engines; very nice too.
    You will retain some of your old harness to keep your factory gauges working. The rest, to make it neat, you can cut away. You also need a tach signal divider to make your dash tach work if you have one.
    You need a newer fuel pump. I would just go ahead and do the Walbro.
    To keep a/c, you will have to notch the frame or use the Street and Performance compressor.
    You have to figure out what to do for a cooling fan; belt driven or electric.
    If you have a v-6, you might think about a bigger radiator.
    I got lucky and with the engine and trans in, the crossmember lined up perfect and a driveshaft from an automatic trans truck went right in.
    Theres more, but I'll have to remember.
    Nov 2006
    Thanks man I appericate the help. I think im gona pretty much keep mine stock. What all does it take to put a ls1 intake manifold on one?
    Dec 2003
    Newark, Tx.
    LS1 accessories
    Nov 2006
    Cool man thanks
    Apr 2006
    I did the exact same swap (93 chevy,Automatic, 5.7 to 5.3L from 2002 silverado) mine is 4WD
    some things needed
    *crankshaft spacer
    *motor mount adapters
    *starter
    *Alternator
    *power steering pump
    *custom y pipe with 2 o2 sensor bungs
    *high pressure fuel pump (got mine from summit, edelbrock part #EDL-3581)(it's actually a walbro pump)
    *wire
    *relays
    *custom PCM program
    I would definately recommend getting a subscription to Alldata as I did (or something similar) for your 1993 and the vehicle the new engine came from. It will help a great deal with wiring.
    I also learned a great deal from the people on this board (very knowledgable)
