Results 1 to 10 of 15
Thread: Does an LS1 swap into a 4wd the same as 2wd truck?
    Nov 2004
    Ashburnham
    I have noticed most people on here that have done the ls1 swaps have 2 wd trucks. I have a 4wd truck however I am disconnecting the front drive shaft because I blew my 10 bolt and am having a 14 bolt re-geared with 4.10s. I dont wanna gear the front with 4.10s seeing im not driving the truck in the winter anymore and am hopefully putting the T56 in at some point. Do the LS1s swap in the same in the 4wd trucks as with the 2wd? I think the frames are different in front.
    thanks,
    Mike
    They should swap in exactly the same since there were no differences in engines from 2wd and 4wd. Oil pan configuration would be the only difference. Have you cnosidered tossing the transfer case along with the current engine and transmission? You'll have less parasitic HP loss with it gone plus you'll save another 100 lbs of weight you have to take with you everywhere you go. That should improve your 60' times and fuel mileage.
    San Marcos Texas
    You could also get rid of your front diff and gut your front axle shafts down to the hub stubs.
    Dallas, Tx
    Also might want to consider where the oil filter is going to be once the LS1 is sitting in your truck. Dont want it stuck behing something where you cant reach it. That would really piss me off having enjoyed a new engine for 3000 miles (500 of its brand new internals) only to have to take it all out to chane the filter :p
    Shane
    1996 GMC Yukon 4x4 4-Door. Bone Stock for now. Need Moneys.
    Nov 2004
    Ashburnham
    Oh yes transer case, old engine and tranny all are getting the toss. I just put in a 14 bolt rebuilt with Yukon 4.10s and an eaton posi. I blew up my ten bolt. Anywho the front drive shaft is already taken out because I didnt wanna change the gears in front and I dont use it in the winter anymore so I dont need 4wd. I will gut as much as I can when the time comes. I just wanted to make sure that the swap was the same with the 4wd frame and components.
    thanks,
    Mike
    Feb 2005
    All I had to do was use the oil pan from a truck motor (4.8,5.3,6.0 they are all the same).
    New Truck on it's way: '07 Classic GMC 2500HD DuraMax LBZ
    03' Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99' Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02' PCM, LT1 fans
    I used the truck pan last time on the 2wd. Allen used the f-body pan on his 2wd. Most everyone I know used the car pan but we're mostly 2wd.
    Feb 2005
    Also I believe the truck pan holds about 1 more quart than the F-body pan too.
    HP Tuners
    Dallas, Tx
    f-body will show full on 5 quarts, my 5.7 L31 shows full on a little more than 5 1/2 so yah the truck pan is definately a tiny bit larger. Hey Greg, give me an LS1 and we'll try it in my 4WD
    Shane
    Feb 2005
    Originally posted by Shane_S+Sep 16 2005, 03:35 AM--><div class='quotetop'>QUOTE(Shane_S &#064; Sep 16 2005, 03:35 AM)</div>
    <!--QuoteBegin-Zick
    f-body will show full on 5 quarts, my 5.7 L31 shows full on a little more than 5 1/2 so yah the truck pan is definately a tiny bit larger. Hey Greg, give me an LS1 and we&#39;ll try it in my 4WD
    Shane [/b]
    I wasn&#39;t referring to the 5.7 L31 vortec truck oil pans. I was talking about the LSx 4.8,5.3,& 6.0 pans. These hold 6 quarts.
    The L31 pan will not bolt to a LS1 anyways.
    New Truck on it&#39;s way: &#39;07 Classic GMC 2500HD DuraMax LBZ
    03&#39; Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99&#39; Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02&#39; PCM, LT1 fans
