Results 1 to 10 of 20
Thread: good cam for a 5.3?
    Jan 2010
    Cedar Park
    good cam for a 5.3?
    Looking at a comp LSR 227/235 .614/.621 113LSA its going in a 01 reg cab short bed 373 gears 3k stall. Plan on changing to a 3600 stall later. Input appreciated
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Arizona/Utah
    That is a very big can for a 5.3 are you going to be spraying and do you plan to drive it other than racing? Behind a 3600 it will be pretty good, but behind a 3k it will be a dog down low. I would suggest something a little smaller. 224/228 is a great 5.3 cam.
    Jan 2010
    Cedar Park
    It already has a 224/230 in it now. Looking for a little more power above 3500. Plan on porting the heads and adding a nnbs intake n 90mm tb
    Arizona/Utah
    I don't know how much more you will really get by changing cams. Porting the heads and allowing it to breath better will help IMO, but changing the cam seems like a waste of time to me. For a small motor I think it will move the power band move up, but it won't net valuable gains unless you are planning to run 65-140mph roll races. You will want 4.56 gears for that monster cam.
    Jan 2010
    Cedar Park
    Well 65-140 is where its at!!! That my plan. I have seen lots bigger cams in 5.3s. This will strictly a highway roll truck.
    Arizona/Utah
    Quote Originally Posted by GraniteBlueNNBS View Post
    I think your money would be better spent on spray if you are going to be roll racing. The cam you have now is such a good cam for a 5.3. A max effort cam verse the one you have will net you 10-15hp. You will be much better off bolting on 150hp that you can add at the touch of a button. Roll racing is mostly about horsepower.
    Ponca City
    Useable Hp > peak Hp.....
    Slowest in Oklahoma...
    Jan 2010
    Cedar Park
    Well im also wanting a lil more thump at idle. This cam isnt even notible
    Jan 2010
    Cedar Park
    What about comp 223/231 610/614 112lsa. Wanting more thump n a lil more power this is a lsr lobe vs xer lobes. Will be adding new lifters n springs.
    Aug 2012
    Mount Pleasant, Tx
    A 224/230 is not noticeable at idle??? What is the lobe separation angle? Through a stock exhaust?
    2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
