Results 1 to 10 of 18
Thread: School me.
    Jul 2010
    Douglasville Ga
    School me.
    I have done quite a few GM EFI powertrain swaps including LS family DBC and DBW. I usually completely rework factory harnesses but have built a couple NEW ones as well.
    However I am still a little unclear about the differences btwn the red/ blue and green/blue Gen 3 PCMs. I have noticed differences in HO2S wiring and I think alt wiring.
    What, if any other differences are there. Can either be used with DBC or DBW assuming proper cal application?
    What are the different options for alternator wiring? Can the brown wire go straight to a charge indicator lamp provided that gen f terminal dtc is set to not reported? Does the gray wire always need to be ran to the PCM?
    Thanks guys...
    Nov 2006
    Mesquite, TX
    Yes, this site has a write on how to do it. It's as simple as pinning the PCM providing the PCM can control the IAC, not all can. My 03 PCM I tried using wouldn't so I picked up a 02 PCM...harness I used is a 05 6.0/80e harness. A few pins needed to be swapped or added but it was pretty easy. So 05 harness with 02 PCM and it's dbc
    Jul 2010
    Douglasville Ga
    I think I should simplify my questions.
    What are all the differences btwn the red blue and green blue pcms.
    Can either be used with a cable or tac?
    What are the options for alt wiring?
    The blue and red connector harnesses are 99-02 and you should use that year pcm.
    The green and blue connector harnesses are 03+.
    You shouldn't try to swap between the two with pcm's.
    Jul 2010
    Douglasville Ga
    Thanks, can the green blue pcms operate an IAC? Can the red blue pcms communicate with a TAC module via serial data? I do have a tuning software suite and can load the proper os and cal.
    What exactly are the differences btwn the two pcms? Is one exclusively 512k?
    For example, if I wanted to convert a blue green DBW harness/ pcm to DBC, can I keep the pcm and just rework the harness or would I have to use a 99-02 pcm?
    Vise versa, could I use a red blue pcm in a DBW application?
    What about alt wiring? How many different schemes are there?
    Some of the '03 and I think '04 express vans used the mechanical throttle body, that is one vehicle that is an exception to what I stated above, but I'm not sure what pcm service number they use.
    For the general rule, no, don't flash an '05 calibration into a 2002 pcm, weird things happen. They have different hardware internally.
    You can convert the dbw harness to a cable operated one, but use a 2002 pcm.
    Jul 2010
    Douglasville Ga
    Cool, so red blue pcm = DBC. Green blue pcm = DBW.
    I will keep this advise, thanks!
    Now can you or someone school me on HO2S variances. Is it just case grounded or not case grounded and wire them accordingly? Are they specific to early( not case grounded) and late( case grounded)? Anything else?
    Alt variances?
    Thanks a million for your time, I know you are a VERY busy man!
    You'll have to look up each harness by vin to know exactly how it's pinned out, just to be sure, but 99% of the time when we do a cable operated throttle body 99-02, they are case/chassis grounded.
    The newer trucks/cars 05+ seem to be pcm grounded.
    Just a general observation, it's not the rule.
    Almost all the 2002 and earlier use the one wire , flat connector.
    Nov 2006
    Mesquite, TX
    A lot of your questions can be answered in the link I posted
    Jul 2010
    Douglasville Ga
    Sorry, I don't see the link.
