the dbw is much easier to install, you dont have to route a new throttle cable and worry about attaching cruise control. just find a suitable place on the firewall to mount to tac module and then mount the gas pedal. you will need to flash the pcm to at the very least remove the vats anti-theft. You should also disable the egr (if applicable), the evap system, and rear o2 sensors to get rid of an annoying check engine light.
As far as what you need, that depends on what you have. Did you get a complete engine with the wiring harness, pcm, and accessories? If so you dont need much, just some motor mount adapter plates which you can readily find on ebay for $20. Also the plastic vacuum nipple for the back of the intake in order to connect to your vacuum brake booster. You can make your own fuse/relay system but if you're willing to shell out another $40 you can find an underhood fusebox on ebay to plug the engine harness into. There are only 2 or 3 pins that need to be wired to where the other connectors would go. It took 10 minutes to install and looks a lot cleaner than a jumble of fuse holders and relays.
You will need a new fuel pump as well. Go to the parts store and get a fuel pump for a 96 v8 camaro, it is identical to your oem one but is higher pressure and volume to accomodate the engine.
If you are not going to run headers initially then you will need a couple exhaust flanges to mate to your exhaust manifolds. They are a different shape on each side, and i had my exhaust suuplier check their supplier and they didnt have them, so good luck. Fortunately i was able to pay them $50 to cut the flanges off a new y-pipe/converter assy and send the rest back as a "defect." Anywho, once you aquire the flanges have a local exhaust shop bend you a new y-pipe and you're set.
i found it was easy to use my existing starter relay wire on the new engine, just hook it up and it starts like normal. i nipped the end off the one in the new harness and capped it.
are you going to use the stock trans? thats a whole other mess that i dont even want to get into right now because i want to play call of duty, but this will get you started.
1993 GMC Yukon GT, 6.0 vortec, head work, no cats, cai, HpTuned by me, jasper lvl2 4l65e, nbs brake conversion
