Results 1 to 10 of 14
Thread: MAF sensor, which is best?
    Wichita Falls, TX
    Need some input on the best MAF sensor. What do you all recommend.
    stock
    Wichita Falls, TX
    that's kinda what I figured. Truck is running excellent as it sits. just walked a titan on 24's after the truck finished spinning through 1st. I really gotta work on that traction. probably would have got more like 3 lengths instead of what looked kinda like 1.5-2.
    Feb 2009
    mississippi
    stock and your trucks lowerd right how is your pinon angel it could be your track probs
    Stock.
    Wichita Falls, TX
    trac problems are definitely from pinion angle. It is horrible, it's the next thing on the list to be fixed. I'm just not sure if I'm going to use wedges, re-weld the perches, or just deal with until I bag it. I plan on doing a traingulated 4-link or a 6-link later in the year. When I do that I can fix the pinion angle then. I may get some wedges to get me by til then.
    Pittsburgh, PA
    none
    Feb 2009
    mississippi
    if your pinon yoke wears down you will leak trany fluid and prop end up burnin up that trany
    Wichita Falls, TX
    it's straight from the tranny to the carrier bearing. The only thing I worry about is the axle and the u-joints. the original owner already replaced the carrier once so i'm sure I will end up doing that too before too long.
    Feb 2009
    mississippi
    o yea ec ha ha i wasin thinkin about that ha ha my bad
