Results 1 to 10 of 26
Thread: Another 4.8 to 6.0 swap question!!!
    From reading posts on this wonderful website... I now HAVE to do the swap.. My question is whats the difference between the lq9 and the lq4? I think i found a great deal on a 02 lq4 motor and tranny for $1600 with 60k on it. Is that a good starting point? Whenever i swap the engines around who can reprogram my cpu? thanks for any advice you guys can give me!!
    Better rods and flattop pistons in the LQ9 (higher compression) otherwise most of it's the same...unless they are both early versions where the 9 also has floating pistons, right?
    Waco, TX
    what is wrong with your 4.8 and how many miles are on it?
    4.8
    Theres nothing wrong with it... Just wanting to go with the 6.0... Its got 68k on it.
    May 2006
    Waco TX
    That doesnt seem like a bad price. What route are you planning to build the motor? If you want the turbo or supercharge then go LQ4. If you want to build an N/A beast go LQ9. The LQ9 has 45 more stock HP I believe than the LQ4. If you get an LQ9 you can keep your current transmission.
    It's a 20 horse difference stock 325 vs. 345 in most trucks.
    Pittsburgh, PA
    and only cause of .5 in compression
    for ever .5 in compression its roughtly 15-20hp gain or loss
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    May 2006
    Waco TX
    The earlier LQ4s had 300 right?
    Pittsburgh, PA
    Quote Originally Posted by Red03SilSS View Post
    iron
    412 Motorsports
    Yes, the 99-00 LQ4 has 300. The 99 has iron heads and block.
