Results 1 to 5 of 5
Thread: Sending unit help
    Sending unit help
    I got my sending unit and pump in today. There was a rubber bushing that looked to go on the sending unit where the pump rest but i couldnt get the pump to fit with the rubber peice on....Do i have to use this?
    Jan 2006
    Middleburg,FL
    You mean a large O-ring? If so yes that seals the pump to the tank. You might have to lube it a little.
    No, Im talking about the rubber peice that the is on the sending unit where the pump sits. It is between the pump and the sock on the metal part where the pump is suppose to sit. It is an 87 style sending unit and an ep381 pump.
    Jan 2006
    Middleburg,FL
    what is making it not fit? Is the rubber line that goes to the pump too long?
    houston
    why did you get a ep 381 pump?? ive only heard of the ep241's. and yes im sure its necessary so it doesnt vibrate/rattle around.
    clint
    1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT and HID projectors - also for sale @ $8,500
    A poor man buy's it twice
