Thread: Tear Down Problem
    Jan 2006
    Middleburg,FL
    Tear Down Problem
    I'm having a problem getting my crank pulley off. I've gone through 2 pulley pullers, looking for any ideas or something that might work.
    Apr 2005
    Go to O'reileys or Vatozone & rent a 5 or 7 ton 3-jaw puller.
    Gone, but not forgotten!
    Jan 2006
    Middleburg,FL
    I'll give that a try. Thanks
    If you're breaking pullers you're doing it wrong. You should be pushing only on the bottom of the hole. If you're pushing on the flange with a flat pusher bigger than about 7/16" then your just pushing on the pulley.
    Dec 2003
    Newark, Tx.
    The best puller I have came from Sears. Its $70.00, but well worth it.
    It has a spin ring that will clamp the jaws down so you dont have to hold them.
    San Marcos Texas
    I bought a cheap puller from oreliley's and it worked great. If you pull on the little flanges on the inside of the pulley, the pulley will hold the jaws from popping off. I left the bolt in but only threaded in a few turns to press against. The puller I used is a little larger than the one in the picture. I think it is a Chrysler 3 jaw puller.
