Can anyone give me a lead on an inexpensive DBW pedal? So far the prices I've been quoted were in the $150 range. That seems steep to me.
Thanks,
Bob
Thanks,
Bob
Seems about right to me. However, i did get mine for free from the guy who sold me my 5.3.
01 Silverado - 2004 5.3L Conversion from 4.3L V6 - Wheatley Tune - One Wheel Dance Off Champion
http://shaggypokertables.com/images/sigblack.jpg
NEED VW WORK OR PARTS? PM ME!
try here. Contact Us
that's where i get all my stuff.
83 sb chevy 2wd 350 vortec, performer rpm intake, holley 700dp,stock lt1 roller cam 3500stall and 3.42 gears
13.59@99
Thanks for the lead, I sent an e-mail tonight.
Bob
if you can score the two togther (pedal and module). i got mine off eBay
for $80 for the pair.
one thing to watch out is the compatibility, some TAC modules and pedals
my cause irratic behavior if not matched. i went through three TACs before
finally getting the pedal and TAC from the same donor truck. eith the throttle
was slow, unresponsive, or irratic and unconsistant.
doesnt matter if from a silverado/sierra 4.8/5.3/6.0.. just so they match.
airdeano
1965 C10 5.3L/4L60e (300HP 4-Speed)
http://home.comcast.net/~airdeano/1965/img/196531.jpg
http://home.comcast.net/~airdeano/1965/index.htm
So does the harness have to match or the pedal with the TB? My engine is from an 04 Envoy but the harness is from an 05 Sierra.
So just what is the tac madule and what does it do?
Thanks.
TAC - Throttle Actuator Control module translates the pedal signal to
a dc motor signal forthe throttle body.
airdeano
Thanks, that confirms the conclusion I came to while I was sitting in the hot tub. Someonee else had called it a tach box and that really had me going.
So the problem matching that you had, was it the module or the pedal that was in conflict?
Bob
Just get matching pedal and module from the same year group (99-02 and 03-06) and you should be fine. I've heard that if you mix and match year groups then that is when you start running into problems.
PCM ===harness=== TAC module ===harness=== Pedal
That is how it is set up.
thats what i ran into...
using the SSR VIN and programming and a 2003 c2500 TAC and pedal.
all screwed up... changed VIN to 2003 silverado/sierra and viola! el worko!
SSR parts maybe the same, but price is usually higher like that of the
corvette.
airdeano
