Im pretty sure it will but just want to make sure before i go buy the boss. thanks
its a 4l80e out of a 1998 2500 im going to put it with my 2002 6.0 swap that im working on
Will work just fine. Just tune for it and follow the swap thread on here
I used a 96 fuel pump, for the vortec 5.7's. It bolted right up.
Acdelco ep381?
Id prefer to stay with Walbro, i just dont know which 255 kit to buy. Theres one for the camaro, and it looks like id have to splice the wires in (which is fine) and then theres the universal one. Any help would be appreciated!
Heres the 2 im stuck between....or if you have a different Walbro pump to suggest, feel free
http://www.summitracing.com/parts/VPN-GCA758-2/
OR
http://www.summitracing.com/parts/VPN-GSS341/ <-----universal, but doesnt come with wiring
The pump u want part number is gss-340 and order it with plug and sock. It's 125 all together threw summit i believe just installed one 3 days ago on my buddies truck
why does it say its for a ford?
It's for the ford mustang factory but works perfect in Chevy apps. I've used one in both my trucks. And my friends. They perfect. It's almost identical to factory
I found this one instead, goin to try it out and see how it fits. Thanks for the help!
http://www.summitracing.com/parts/EDL-3581/
I think u need a spacer on the flexplate to bolt to the 4L80E trans. I'm doing the same thing and thats what i heard. Check out street and performance at hotrodlane.com. Also what r u using to control ur 4L80E? A stand alone or factory computer?
