need help on my first LS conversion,04 LQ9 in an 86 K5, no start
My computer has been reflashed and VATS removed. I have good fuel pressure and plugs are wet. I have random and weak fire only on 4 and 6. I have checked pinouts over and over and grounds but do not have 12v supply voltage to the crank sensor if I measure right at the pcm at key on with sensor disconnected. With it connected, I get .5 volts with the key on and off. Fuel pump signal is good to relay and injectors are firing. I can connect a code reader and it communicates and shows all monitors ready to learn. Bad PCM?
thanks
