PM ray and jon and see if they can assist, check pinout, ohm, etc.
You should ohm out the wires between the PCM and the TPS sensor plus double check the wires are going to the right PCM pin location. Have you tried swapping out to a known good TPS? Where are you located?
Finally ordered a stall verter from circle d. 32-3400 can't wait for it to get here
