Big Red, although I've checked all grounds several times. I must have yanked one out of the crimp the other day when I dropped the passenger side downpipe. Reconnected ground and now have injectors firing. Allen was right, something happened that was coincidental to the learn procedure. After repairing ground, still wouldn't crank. Got desperate and gave it blast of either down the tb. Fired right up for 2 or 3 seconds and sounded good like timing and everything was right except it ran out of fuel. I think I either have water in the fuel or the octane has just evaporated cause the back end of the truck has been sitting out in this 100 degree heat and sun for a couple of months.
I'm going to drain the lines and tank and put some fresh fuel in. If that doesn't do it, I'll have injectors checked, but when I pulled the fuel rail and touched them with 12v, they all were spraying the fuel left in the fuel rail.
What do you guys think? Again, thanks for all the help.
