Sweet ass engine.
Sweet ass engine.
hey guys its been about a year since I did the swap and I'm trying to get my tach to work, at first It work was reading wrong but it work for about a week until we made some adjustment on the tune so that it would work fine. then I changed to a local tuner for better results as far last tweaking.
ok, the setup is e67 /t42 tcm with 08 tbss operating system. we changed the tach signal from pwm to crank and I believe we set the high and low signals to 7. but it will not read any on the tach I tried using a pull up resistor 1k ohm 1/4 watt and it still wont read.
any thoughts?
Which gas pedal did you use?
the gas pedal is for a 08 tbss , I made a bracket that allowed me to bolt it in the stock bolt holes, I changed the pad from my stock pedal since the new one looked funny compared to the brake pedal,
