so a tbss intake will bolt on, using tbss fuel rails and my stock o5 injectors with only lengthing the map sensor harness???
sorry banker, i kinda changed thinking over to keeping my stock heads and just adding a tbss intake, 90mm tb. and xlink. just want to make sure the intake is a bolt on deal. seeing what all has to be modified to get it on and working such as fuel lines, evap lines, wiring etc.
Im Working On Uploading Some Install Pics From The Swap Right Now.
If you are just looking for more bottom end, I doubt you need the 90mm throttle body
