How close is close? lol theyre about 4" +/- up on the header...
Yeah sounds like a VATS problem, get Nelson to delete it in the tune... as for the oil pressure gauge, use a factory 5.3 sender, should fix you up. I know my LS6 is the same, I used a CTS V sender and it is pegged over 80, just have to swap it for a truck sender to match the harness.
Got the rev problem fixed... i pulled a bonehead caper... somehow the left bank wires had come unhooked and it wasnt getting spark or fuel cuz of the way i tied the injector wires and coil pack wires for each side in 2 bundles. Hooked those back up and it runs and drives like a DREAAAM!!! :D for those of you considerin swapping from a 350 tbi to a 5.3... there is no comparison!!! The 350 never thought about havin the power the 5.3 has!!!!!!
Glad to see you got it fixed
This is a good rule of thumb, but thinking that 2" placement difference of O2 sensors is going to effect the engine's ability to idle significantly is just not realistic. The 02s on my GTO are nowhere near 6" off the collector and I have zero issues with the tune.
Just the motivation I need! LOL
Are you planning a swap into a truck?
Glad to hear about the oil pressure issue I never heard about that problem. Which adapter did you use?
I had a brass bushing i bored out and tapped for the obs sender.. did the same for temp sender. Didnt cost me anything but time! :D
