If I understand correctly, early is 99-02 and late is 03+. Im still a little unclear about weather or not a blue green pcm can be used with dbc or if a red blue pcm can be used with dbw. Don't use the pinouts here as a view, but rather just for the cavity numbers, that way there will be no confusion about weather you are looking at the front or backside of the coonector.
