nitrous, if I can get a ramjet manifold, how do I run that? will my computer work, In regards to your NOS system, were you using a WOT switch to activate it or a time based system?
The switch is hand held and is threaded into an aluminum joystick I made for better control. Plus it eliminated the switch under the hood so the kit is completely hidden. If you ran the ramjet manifold you would have to run the stand alone module that comes with it. It's a pretty easy installation compared to an LS1 swap. You might want to consider the Holley Commander system also. I'm sure it's better now than when I was looking.
