Forgot to mention I am in the middle of a 5.3 swap at home. Its a 72 k10 on 35s owned by a 17year old. Starting his senior year in two weeks. Fired it up late tonight. Should have it ready for his first day back. Cool stuff.
you must post pics or you are a proud member of the sadistic society !!!!! ;)
Will do. Does photo bucket work here? Ill start different thread will my conversions to date.
yes, Photobucket works perfect...is what I use !
I have an alt not charging after a swap. Its an 04 truck alt with a 99-02 red blue pcm. I have the brn wire from alt pinned to 15 red. Have the gray wire pinned to 52 red. Also this is in a 72 c10. I want the charge indicator to work. Any tips?
Oh, so basically the 04 pwm alt is not compatible with the 99-02 pcms? The connector is a flat 4 pin. Is that the connector you speak of?
