Is this what i should buy?
http://www.google.com/products/catal...CAcQ8wIwADgA#p
Ditto on ditching the rears
I actually just put a set of Alpine Type R 6.5's in my Blazer...I'm in LOVE. Million times better then my old Pioneers, which were a million times better then stock.
I still have my rears with some added tweeters and can fade them in and out and tell a difference, meaning I can still hear them. I like hearing the music around me instead of in front of me. Just sayin with the added amp and good speakers, you can hear them.
You can hear them, that's the point of getting rid of them. They are mucking up the fronts.
Well I guess for me it works since Im 6'6" and have to sit way back to fit in an ext. cab.
I hear my rears too, I'm only 5'10" but I G-ride so my head is usually even with my b-pillar. I will be adding a set of the same Diamond components in the rear doors just to have them back there so I have better sound(maybe), but I don't feel they are absolutely necessary given the price of a set of good components. I do sometimes like to say: go all out or go home.....
Will i be ok with a 4g power wire with 2 amps, one 400 and the other is 1000?
I've done many pairs of 6.5's only issue is mounting depth, 4x6's (or any oval in my opinion) is a waste. The only 4x6 I've ever liked are the plate type that have a 4" round and a tweeter.
Probably not unless you are using 4g to each from a 1/0 and distribution block or 4g each from the battery. The 400 would probably be okay on good 8g.
