haha, yes. it does. it also has a built in amp that puts out 50watts RMS to the speakers, which just so happens to be the max rms that my infinity speakers can handle. for speakers and a head unit, it all sounds pretty nice
I dont think any deck puts out its claimed "RMS", maybe half of it to be realistic. :)
hit up a few pawn shops, everyone is broke and stereos are low priority, might get every thing you want cheap enough to get it all at once.....
yessir, they will do 50X4 for about half a second. your continuous is usually half of that
rms is 24/7/365 available power output based on VOLTAGE supplied at that moment. so it varies up or down based on the actual battery voltage at that given moment.
h/u wise i prefer pioneer (since premier is no longer) i have the premier 610bt in my 99 burban. it has built in bt, usb ipod hook up and it is a single din install.
plus its under 250, then you add the aftermarket harness depending on your vehicle and dash kit and antenna adapter and install... your 250 radio goes upwards of 350+ with installation costs added to the price.
