And what shall your decision be?:D
One more comment on the frame notch. If you look closely the only reason the frame is that wide up front is too move the Idler arm over for positioning. If you look at the frame behind the crossmember and on the drivers side also you'll see it's much narrower.
Good post guys, I've been racking my brain trying to figure out how to mount this AC like it is from the factory. Thanks.
