Quote:
I have seen the jet 4th gear servos and the Jet 1-2 servos and have heard yall talk about corvette servos and was wondering which one are reccomended and what the install is like on the because i have heard its not to difficult. Also what gains will i see or changes should i expect to occur when shifting
Don't know anything about the jet servo's. I put a vette servo in my stock trans. The term vette servo refers to the design of the unit. Larger surface area to apply more pressure on bands at shift vs the stocker. It isn't to difficult. Tedious. Not much room with the trans in, to put it in , or wasn't in my truck. Took a while to get it in and the c-clip back on cause I couldn't install it all together. I also had some trouble changing out the spring in accum to it. Holding it together and compressed so as to install the c-clip in it. Also a little trouble putting the final c-clip that holds the entire thing in. Was easier the second time around. It will firm up the 1-2 shift significantly.
