This will be my first swap I know it can be done. Is there anything I should know before I get started?
New motor mounts? I have a 350 tbi.
Will it connect with a 4l60e?
Will the 6.0l stock tranny fit in the truck if I replace the 6l60e?
yes you can use the original 60e or you can use the 60e from the 6L. you can get dirty dingo ls swap mounts that way you dont have to change trans cross member location. We can build you a custom stand alone harness, all your gauges will work with some simple wiring. you cam email ray@nelsonperformancecom
