Fuel pressure surge 5.3 swap
1992 k1500 blazer
5.3 swap from an 03 Avalanche
4l60e
3k stall
212/218 .600 cam
Walbro 255
I did a 5.3 swap in my blazer, from day one it has not ran correctly I can’t even drive it because of has such a bad misfire. I have spent the last couple of months troubleshooting and throwing money at it but so far I have no improvement.
It has a misfire but it isn’t throwing any codes, I did drive it once and within an 8th of a mile it threw a P0101 code, i had to clear the code for it to run again.
I have replaced the fuel pump , filter/reg, vac hoses, intake manifold gasket, MAF (with a used one) , I cleaned the Injectors and throttle body.
I use torque pro scan app, it shows no codes, no misfires, o2s are switching.
Here is a video of the fuel pressure https://youtu.be/S-UbH5Ogdq8
Here is another form thread with more detailed info. https://www.ls2.com/forums/showthrea...e-tech-support
Does anyone have any idea what the problem could be?:shots::whack:
