injector help
can i use these? thoughts opinions?
80 lb Short D5 High-Z Fuel Injector MT
Item Code: FI114700
Weight: 40.50GM
Manufacturers : Siemens (Continental)
Stock: Yes
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: A2C32624700
Coil Resistance Ohms: 12
Spray Pattern: Cone
Series: DEKA 5
Connector Type: Minitimer (Bosch EV1 - Jetronic)
O-ring Type: Viton
E85 Compatible: Yes
Weight (non-shipping): 29GM
Test Pressure PSI/KPa: 43.5/300
Test Solvent: Heptane
What are your goals and what will they be used with? I think the simple answer should be yes.
600whp.. possibly a bit more.. on 2001 stock intake...
Gonna push 600 thru a stock truck intake? Should be fun. (not saying it can't be done) Should be plenty injector for the power level especially at higher fuel pressure. I am not sure about the connectors or length though.
yeah the length is what im most concerned about connectors are no biggie
Stock intake is fine. Your pushing the air in anyways I would assume, the shorts should be fine too. its the car ones that are longer.
make sure the injectors arent too short; if they are you will need some of those aluminum injector spacers; if they are too long you can easily raise/space the fuel rails.
the connector isnt the same, you will need injector connector pigtails for a 2000 camaro style injector connector, ev1.
I was looking at these as well but, 34.5mm from o-ring to o-ring.
Cant find stock injector height 0-ring to 0-ring........does anyone know stock injector height from 0-to-0?
In my research they are supposed to fit the intake on the G8 is LS2 length I believe.
