idk if i put it in the right section but, i got drop spindels and springs but my alignment is off cuz its eating my tires from the inside.. what can i do to fix it?
yeah i got it aligned but its still eating em, ive hird to put the djm arms but i really dont want too low cuz it already rubs sometimes
I had the same problem, i have a 2/4 fronts on Djm coils. Turned out it was the alignment. Got new tires and had it cheaked it was still under warranty.
let me see if i can find the sheet.. springs are djm and spindles are belltech
That's the nature of the beast with modified suspension. There are aftermarket alignment cams that give more adjustability, which may fix your problem. The other issue I've had is the alignment tech not tightening the alignment cams all the way. Also check the ball joints.
