Got the engine, Now I need input...
I have been reading and have some useful info. But I have a few ?'s regarding what I have. I recently purchased a complete L33 and auto trans. When it was removed, It was completely unplugged and the only thing that was cut was the fuel lines about where the shift linkage is. It has all accessories including wireharness, computer, motor mounts, exhaust manifolds and pipes were cut off about 4" below the O2 sensors and finally the electronic gas pedal. All of this is going in a '96 GMC sierra.
So, with that said, I have ?'s because everyones set up is different and not all set up are complete so things have to be fabbed.
1. Do I have to have the wire harness modified? If so, why?
2. Is the fuel pump in my 96 big enough to feed it?
3. Unless I go ahead and put a cam in it, do i need to have the computer tuned for any reason?
4. Has anyone found a way to run the a/c in its current location?
I have more ?'s but these are the ones that are most pressing for me at the moment. Thanks.
