I put an 06 lq4 in my 04 Sierra. I used the flex plate off my 5.3 to bolt up to the 60e. If I get a 4l80e will I need to go back with the lq4 flex plate? If I do that will I need to get the spacer also?
Yes u will need both
After looking at the flex plate That came with my lq4, it looks like it has the spacer on it. All I need is an 80e now amd I'm ready to go lol
Also dependes on what converter your using.
Oh, I didn't think about that. The converter I go with will determine if I need the spacer or not?
Kinda. Some converters like the 6.0 stock one will use a 6 bolt pattern and require the flex plate with spacer. Some converters use the 3 bolt pattern and will use your dished flex plate like your 5.3 one.
Ok, thanks. Good info to know. I should have searched a little more, probably would have found this out, but I'm being a little lazy.
