1994 OBS to LM7 swap, Am I missing anything?
Hey all, new member who needs help.
I have a 1994 silverado 2 door step side with a 350/TBI, 4L60E, 2 wheel drive.
I am looking to buy a LM7 5.3 to swap in and am having a bit of confusion. Will it be cheaper to keep the fuel injection or go with the carb conversion?
First off, I have been told that the 4L60E in my truck was the first year for the silverado's, so it has the old wiring harness that won't connect to the newer harness.
Also, I want to know if I make the 5.3 harness a stand alone, then what do I do with my original harness, and how do I make the trans work with the newer harness?
What I am thinking about doing, but don't know if it will work.
1st, I can buy the 5.3 and make it a stand alone harness and leave my truck harness hooked up to run the guages, and somehow convert the trans harness to the new style?
2nd, I could buy the carb conversion kit and get rid of the whole wiring harness issue with the 5.3 and rig the TPS sensor onto the carb so the 4L60E will still work.
I have about $1,500 to $2,000 to make this happen.
Here's what I figure i need to buy or address
5.3
motor mounts
headers
e-fans
DBW/throttle body or carb conversion
Wiring harness, original one and 5.3 harness
fuel system
I am removing the A/C
Thanks
