Changing the fluids this weekend, need some tip on what to choose (Diff, Trans, &Oil)
I use to go with Mobil 1 synthetic for my oil but now I've heard they switch to a different base oil which changes it up or some sht.
1) What brand oil do you use and what weight? I know I will probably go with 5/30 like usual and won't ever change. Probably going to buy Royal Purple if Autozone has any.
2) How many quarts do I need for the trans and what brand/weight do you use?
3) How many quarts do I need for the diff and what brand/weight do you use? Do I need the G80 additive too or is there a double mixture with the diff fluid that already has it?
