how does this build sound?
new to the forum...this site is sweet iv been reading so much on here the past few days :rock:
i recently found a lq4 at a junkyard from intake to oil pan for $175 it kept fouling plugs n ran like crap
ill tell you what the plans are...as of right now i drive a s10. i am going to sell it, buy a 99-02 z71 and have the lq4 ready drop in...
ok so now about the motor.
its out of a 2001 or 2002 box van
stripped and hot tanked to be cleaned
stock rods and crank
bored .30 over to make it a 370 to clean the walls up
have new freeze plugs and cam bearings installed
diamond pistons
ls6 cam and yellow valve springs
7.425 pushrods (using stock rockers and lifters)
arp rod bolts and head studs
this motor willl be boosted once in the truck. i am looking for around 10-13 psi.
now some questions i have are...there are a bunch of different pistons...i know i want forged for boost...but there are a lot of dish sizes and what compressions ratio would you recomment?
i know the ls6 cam is not that big but hey its bigger than stock! will those valve springs be ok or would you recommend something a little stiffer? and will the heads be ok stock or what work would you recommend to them. they are stock heads so im guessing their 317s? thanks in advance!!
