deceided to put a three wire sensor in the stock location. what are the pins for that sensor? Is A and B the same and C to the gauge? Just a guess?
http://s940.photobucket.com/albums/a...t=62493966.gif
This is the diagram for your truck. According to it, terminal A goes to your ipc, as far as the other two, it's been a while since I've had to work on one of those but I believe one is 12v and the other is 5v, but I could be wrong. I'll get some better diagrams off mitchell at work tomorrow. I only have access to this alldata crap at home. Hope this helps.
I am refering to the three wire sensor that was refered to in the parts list as a three wire temp sender for a replacement for the 2 wire one that just sends the signal to the computer. it is not the stock one, that is a simple one, one wire.
The three wire sensor, the middle wire goes to the gauge, green, I believe it was. It has been about 5 years since I dicked around with one of those, though.
thanks
http://i69.photobucket.com/albums/i6...ch/coolant.gif
A = black(gray 6.0)............coolant temp input to ecm, low reference
b = yellow...........coolant temp input to ecm, sensor signal
c = green............coolant temp input for cluster mounted temp gauge
Where did you get the three wire sensor?
The 3 wire CT sensor part number is #12551708
The connector pigtail is part number #12102748
Jeff
Thanks .I ordered it.
